DIS plugs
2slosho
tampa
After changing my head gaskets and all maintenance due at 100000, I put the intake on and I must have routed the DIS wires wrong behing the rear timing cover. doh Now they are about three inches too short. At this point I am not up on the idea of disassembling the entire front of the engine. Can I cut and re-splice the wires?
TIA
Dave
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Just to make sure, are you routing the connectors UNDER the crossover tube (in between the timing cover and crossover tube)?
If you try to route them over they will seem short. :)
Otherwise, yes, you can simply sut and slice the wires. But personally, I would rather tear it down again shrug
2slosho
tampa
Yep. unfortunately. And to think I thought I was done. squint
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
2slosho:
Dont worry, Im in a similar situation.
I just completed a 60k and I think Ive got a cam seal leaking headbang
The work is never, ever done jpshakeh
2slosho
tampa
Right. I finally got my 14X1.50 tap today. If anyone needs one I'll send it to you. thumb
