Yes, it will fix the spacing issue.
Inspect to see if you have had the SFB bolt recall done. Do this first to make certain you don't have a failed mounting point.
Since you are so close to the strut right now, I would strongly suggest getting the SFBs installed ASAP. I would also remove the strut damper temporarily to prevent damage to the DIS from its striking the strut.
Also, check your motor mounts to ensure that are not contributing to the mis-positioning of your engine.
Drive the car very gently until the SFBs are replaced and the motor mounts have been inspected, and if needed, replaced.
Steve
<small>[ July 23, 2003, 09:16 AM: Message edited by: projectSHO89 ]</small>
