dirty intakemanafold
SHOTIME
Giver of life
Boston Ma.
yes, The car will run alot hotter if the intake is dirty, And the car will be a bit slower. Its said its about a 4 HP difference.
"If it has wheels or a skirt, you can not afford it"
"Bottles are for babies, Real men get blown"
mailto:[email protected][email protected]</A>
http://people.ne.mediaone.net/billebobob/index.html
Since the air flow is so low at idle speed, a dirty intake would not be of much concern at idle unless it was almost completely plugged. A dirty idle air bypass valve will certainly cause unsteady engine speeds at idle.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
