Direct Fit 13" Rotors?
kevinspann
Don't take my advice.
Richmond VA
Doubt it. The holes would have to be enlarged. Some Volvos (V70R?) use a 13" rotor, but the offset and hub diameter are probably different.
Ishodu
Drilling out the mustang rotors can be done in a elevator room of a hotel in a few minutes. I am sure they can be done at home faster. No need to worry about it.
93markVIII
MO
yeah you can use a big drill bit. i used a grinder and made the slots an oval.
the rotors center on the center hub, so the holes don't need to be perfect.
93markVIII
MO
kevin, do you happen to know what years? doing some research on that.
edit: 06 S60R had them it looks like.
double edit: and they are quite a bit more expensive than cobra rotors. so screw it, redrill the cobra rotors.
Irish Pride
Irish Inside
MusicCityUSA
Just make sure to move the Rug out of they way first so you can sweep the shavings under it. LOL You could hear that thing up in the lobby.
IMGP0454aA30
RedDemonSHO
minnesota
ha ha that was a funny day when you did that and then just covered it up with the mat!!!!
