dimming headlights/dash lights
Rio
West Bloomfield, Michigan
My 1993 ATX has this problem...I noticed that when I have the car in park and rev the engine...the dash lights and headlights get brighter and dim when the RPM's return to idle. Is this a battery or alternator problem?
BlackOnBlackATX
Dutchess County, NY
it sounds like its possibly a little of both. you should have your battery checked to see if its holding a charge or you could take a multimeter and measure the voltage on it, with the car on and off. how old is your alternator? it might not be putting out the proper amount of volts/amps at idle due to wear. i would recommend taking it out and testing it at an auto store, but i know thats kind of a PITA just to test it.
