Hi everyone,
I have a 3.2ATX that isn't starting. It's been sitting for a while so the battery was dead...
no codes in memory. I tried to start it, and I got nothing. I started at the beginning...verified
VREF was in range at the throttle position sensor so I know there's EEC power. Then I checked
for spark - nothing. Then I checked - there's 12V going to the coil pack but when I crank the
engine, the pack's not getting the signal to fire from the DIS module (new plugs & wires). So I
checked the output of the DIS Module, nothing. It is getting 12V though. Now i'm no SHO expert,
but that tells me that either my DIS module, crankshaft position sensor, or camshaft position sensor
is bad. Can someone tell me how to troubleshoot from here?
Oh, by the way, I read the computer which told me 3 3 1 3 3...which i'm assuming is a 33 with
a separator pulse which is some stupid EGR valve error.
Thanks in advance!
-Andrew
Thanks in advance!
-Andrew
