dash board lights
aggiesho
Houston, Texas
i have an 89 and my dash board lights dont work. however the fuse is ok and the lights are ok and i dont know what else could be the problem. any ideas?
aggiesho
Houston, Texas
thanks guys ill look into it. is that something i can rebuild and fix or do i have to find another one?
aggiesho
Houston, Texas
using the dimmer swich i can turn the inside lights on and off but stil nothing with the dash lights. there is the "auto lamp" swich next to it on the right and there is a small light on the front of it and when i turn it to "max" the light doesnt come on and that swich doesnt effect anything. could it be the "auto lamp" or the dimmer one.
aggiesho
Houston, Texas
still nothing. the dimmer switch isnt the problem. is there a relay that could mess them up? they guys at ford said the soldering behind the gauge cluster might have broken. has this happened to anyone else before?
chsw
ga
did you fix your problem? im in the same boat...
