Cylinder compression check
Petersho1
IL
What's the spec.? I got from 182-196 psi or 12.8-13,5 kpa*100.
Can't find it and I have very dirty hands ops! :thumb:
DavidT
TN
don't know the spec.s but those are pretty good numbers. I know this was discussed a while back. Do a search and you will probably find it.
Petersho1
IL
Yes, looks good. I just finish the job, cleaned hands and serched deeper. :dribble:
Rockledge
Pluggin' away
Connecticut
The numbers are solid and within spec. On 3.0L/3.2L SHO engines, the compression reading of the lowest cylinder should be within 85-100 percent of the highest.
