S
shoebilly
Guest
80 a hole is a standard price for a bore.
shoebilly said:80 a hole is a standard price for a bore.
92ShoOff said:Thanks again in for providing the great help!! So would this be what you're talking about to install the pistons?? http://store.summitracing.com/partdetail.asp?autofilter=1&part=ARP-901-9200&N=115&autoview=sku
I've used one of the band style adjustable ring compressors so should I be safe getting the pistons down in the block with that little skill? And what would you recommend for getting the rings on the piston being that I'm using those gapless rings? Anything special involved with those?
So just using the emory cloth a little on the main crank journals would polish them up?? Thanks again!
rangerj said:A good performance machine shop will rough bore the cylinders by machine and then finish the bore by hand. Each cylinder will be finished bored to specification for each piston. The additional labor is what costs more. A bore is not a bore is not a bore! $80 per cylinder is not unreasonable for quality performance boring. You get what you pay for.
rangerj said:I would never ever pour money into a block without having it cleaned, magnafluxed, and measured, including the crank bore, the deck, and the rod bores. Again, a motor that revs in the 7K range MUST be balanced. If you do not do this right the odds are the engine will not last, especially if you want performance.
rangerj said:Compare the cost of doing it right to the cost of a good used motor if budget is a factor. Does it really make sense to spend more on your rebuilt motor than the whole car may be worth?
rangerj said:Yes you can reuse fasteners, but do you really want to risk a catastrophic failure because of a $0.50 nut or bolt? Food for thought.
