92ShoOff
Hey guys, upon tearing down the 3.2 that I plan on dropping in my '92 %-speed I noticed that the cylinder walls have surface rust on them. I'm sure that this should just simply clean up, but if it the even that the walls are actually pitted and slight boring of the walls would take care of it I was considering boring the walls .020" over. Does anyone have any idea how much I might expect to pay a machine shop to bore and prep the 6 cylinder walls for the new piston rings.
I plan on installing Total Seal gapless piston rings, so combined with boring the walls .020" over could I expect a worthy torque and horsepower increase? Or if the walls aren't pitted am I better of just having the walls prepped and installing standard sized rings without doing any boring?? Thanks in advance for your advice guys!
-Andrew
-Andrew
). they are both part of the rotating assembly. If I were you I would question that with them :wave:
I was speaking in general and talking to the woman at the same time and did not realize I didn't add that our engines are internally balanced, I'll slap her later
