trainguy1989
SHOtarted
While working on my rusty ATX SHO, I used a torch to get some bolts off. I accidently melted a hole in my left side CV Joint boot. I found it was easier to replace the half-shaft assembly than to try to replace the boot. My Chilton’s manual says the following: "Due to the automatic transaxle case configuration, the right half-shaft assembly must be removed first. Differential rotator tool T81p-4026 or equivalent is then inserted into the transaxle to drive the left inboard CV-joint assembly from the transaxle." Is this necessary? Could I just pop out the left hand side using a pry bar, like on Phoenix SHO site? The car has 180,000 miles on it too. So is it ok to replace one side too?
Thanks,
David
Thanks,
David
