CV half-shaft. Not being to carful.
trainguy1989
SHOtarted
Wichita, Ks
While working on my rusty ATX SHO, I used a torch to get some bolts off. I accidently melted a hole in my left side CV Joint boot. I found it was easier to replace the half-shaft assembly than to try to replace the boot. My Chilton’s manual says the following: "Due to the automatic transaxle case configuration, the right half-shaft assembly must be removed first. Differential rotator tool T81p-4026 or equivalent is then inserted into the transaxle to drive the left inboard CV-joint assembly from the transaxle." Is this necessary? Could I just pop out the left hand side using a pry bar, like on Phoenix SHO site? The car has 180,000 miles on it too. So is it ok to replace one side too?
Thanks,
David
sperold
Last to Know
I have had boots replaced on my SHO by a local garage for a small amount of money. I think they use some kind of split boot arrangement and nothing has to come apart mechanically. I may be wrong, but that is how I made sense of it (fixed same day for $30.00).
mooseSHO46
Just Hangin
old bridge, new jersey
I just replaced one when it went and I had no trouble with it, unless you feel more comfortable with new axles on both sides.
trainguy1989
SHOtarted
Wichita, Ks
I was just wondering because I have 180,000 mi on the car and I have my front end in pieces. I really don't know how long CV's last.
Thanks,
David
hawkeye18
Sorta cares
Norfolk, VA
The only thing you need to worry about is removing both axles at the same time. IIRC this screws with the diff in some fashion, so just remove and replace one at a time and you'll be fine. You don't want too much torn apart on the car at once anyway; stuff gets lost/confused that way.
walser
new ulm MN
i know that feeling!!
crystizel
