Cutting Moog CCs (859)
hawkeye18
Sorta cares
Norfolk, VA
Holy shat, you got a thread from 2004 talking about this? :eek:
Anyway, DO NOT cut from the bottom. You always cut the dead coils (the ones close together). Cutting live coils changes the spring rate and travel.
I cut one coil from the front and 1.75 coils in the rear. Frankly, I think I should've reversed it, because the front end sits up too high and the ass end sags a little. But hey, whatcha gonna do?
BAM614
Ohio
I cut 2 coils from the front and left the rears stock. Perfect stance IMO and has a nice rake to it. Front and rear fender gap is damn near even, the car is just raked that much.
Mossdahaus
Royal Oak, MI
Hahaha okay cut from top...glad I asked to double check. Thanks for the help as I'm installing the new rear struts and all 4 springs tomorrow to rid my stock rear sagging springs and front 4x4 monroe quickstrut springs
hawkeye18
Sorta cares
Norfolk, VA
Why would you cut the rear springs at the bottom? I don't understand. Everything I've ever heard or read about cutting springs said to only ever cut the dead coils as to not alter the characteristics of the spring.
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Well, not you have me second guessing.
So I went out and looked at my Moog equipped '89
I believe you are correct, in cutting the TOP of the rears is better.
But Im not 100% certain.
Really though, I see no need to cut the rears. As you can lower the ride height a LOT by dropping the strut in the knuckle.
K-Dawg
Treasure Coast, FL
Cut the coils that are closest together. I can't ever tell the difference between top and bottom on the rear springs. I cut a coil out of the front and left the rear alone when I put Moogs on my 91.
On my 93, I could hardly drop the strut 1/2" before the tire hit the spring perch, but I have 8" wheels and 245mm tires.
