Cruise Control Doesn't work
KYSHO
Murray, KY USA
My Cruise Control does not work. Everything else works fine. I have checked the fuses and they are okay. I have also checked to make sure it is connected to the throttle. I don't know where else to go from there. It has not worked since I got the SHO, a 1992. I did search but all the problems were related to non-working cruise control along with other devices such as horn or blinkers. I am only having a problem with the cruise.
Any suggestions?
f$nsho
Idaho
I had a problem with my Cruise Control not working. I ended up being an easy fix. The clutch pedal was tripping the switch that disengages the CC and by simply pushing the clutch pedal up with my shoe :) before activating the CC I fixed the problem.
Wish all things have such an easy fix.
<small>[ April 11, 2002, 01:30 PM: Message edited by: f$nsho ]</small>
fredhurderjr
www.neshospecialists.com
Could be your VSS (Vehicle Speed Sensor) - if this goes, the cruise system doesn't know how fast it's going, and the CC can't operate. Mine was bad in the 93, no cruise.
The earlier SHOs had a problem with the cruise control cable end unclipping from the throttle shaft on the throttle body. I know this is an obvious thing to see, but for you or others that loose cruise function, it is the first thing to check.
scuba
las vegas, nv, usa
i agree with scott, mine has a tendancy to come unclipped - the first time it happened i was on a 500 mile road trip to utah - didnt find out until i got there - man was my ankle killikng me!
