crossed wires, double checking '94 3.2
1slickRED89
Guest
Toledo Ohio
If some one is willing, i need to double check the wire colors for the coil pack and mass air flow meter on a '94 ATX. so post 'um up if you can!
story: I modified my wiring harness to use a 80mm lightning MAF, or so I thought. the engine was not in the car so I accidentally put the plug on the coil pack wires, because they look alot alike when not connected. now i don't have a spark...
I seached, and have Probest's book but both to no avail. Now,I found a diagram here but it says it's for a 3.0L. it says the wires should look like this, is this Right???
coil pack:
back of car
| O |----red/green
| O |---yellow/white
| O |----Yellow / Red
| O |----Yellow / Black
front of car
and for the MAF, i understand that the wires for the newer plug dongle are in the same location with the old and new plug both so it should look like this
Back of car
| O |
Black/green---| O |
tan/Blue------| O |
Blue/red------| O |
Red----------| O |
| O |
Front of car
Thanks!!!
