crank shaft sensor
cowboysfan
la
anyone know the easiest way to change a crank shaft sensor on a 95 sho?
jayro
Auburn, In
Its a little involved. You have to pull the crankk pulley and the crank timing belt sprocket. Check out shophoenixproject.com (sp?) and look at the instructions for a front 60k. Since you are pretty much tearing down that part of the engine, I would do a front 60k if time and funds permit. Have fun
Jeremy
91PDXmocha
Portland , Oregon
Search button is your friend , it's not a simple job find someone who has done it before for guidance if you don't know what it involves .
The low down ... Take everything off the front of the engine .. Replace at minimum waterpump , crank sensor , timing belt . Set timing correctly . Put back together. Probably a whole day project for somone who hasent done it before .
Above link is a great guide . Good luck .
