Crank sensor Wiring
silversho89
Whatever
Around
Ive been doing a cps replacement and now its time for reassembly of everything. My question is is where does the little plastic screwtab on the cps wiring attach to? Ive tried a couple of spots but it looks like when its all buttoned up, it would, in one position, be in the way of the timing belt, and in the other it would be a little too close for comfort to the waterpump pulley/belt?
I was on the shopp.com site and went through the lower 60k info and it didn't say where it came off from or where it went back too.
Thanks,
Rob
silversho89
Whatever
Around
thats where it looks like its suppose to go but i didn't remove the waterpump.
Rob
Off Road SHO
Moderator
One of the water pump bolts is actually a stud head bolt, that is, a bolt with a hex head with a stud sticking out the top. On the ATX's this stud head is at about the 7 o'clock position. The wire loom push clip just pushes right on top of the stud head with no nut to hold it on. I assume MTX's aren't too different.
Tom
