crank sensor maybe?
randy'sho
95 White MTX
High Point, NC
driving home from work yesterday the cel came on twice and both times the car stumbled something bad.....check all the obvious when I got home...this morning i get going about a mile into my commute and wham she starts stumbling again and then it cleared up and wham again and it died, but the tach was still reading over 2k rpm when the car was dead on the side of the road....but after sitting for about 5 seconds she fired right back up and i brought it back home...haven't pulled the codes yet, but sounds like a crank sensor too me....let me know what you guys think....thanks
93rev2sev
Hockeytown
Unplug that cam sensor and drive around for a bit. If the stumbling goes away, plug it back in. That way, when the stumbling returns, you will KNOW you found the culprit.
mrstwistedmunky
Addicted
Yakima,Washington
the car we just bought was doing the same thing and so they replaced the cam sensor...it's still doing it so now i'm replacing the crank sensor...yes it's a bigger pain in the ass but i'm pretty sure that is what it is.
randy'sho
95 White MTX
High Point, NC
okay i read now that you have to start the car first then disconnect the cam sensor...coo thanks guys I will try that!
93rev2sev
Hockeytown
No you don't. That sounds dangerous, anyway. The cam sensor is not needed to start the car...it's just needed to start the car on the first turn of the key every time. If you pull the cam sensor and go to start the car, you may have to try to start it up to 3 times...it WILL start.
randy'sho
95 White MTX
High Point, NC
okay so i pull the cam sensor plug off and the car will barely ideal! rpms go up and down like crazy.....plug it back in and the car runs smooth! ahhh guess i need to go read the codes!
jmpSHO
Massachusetts
Who said a 211 code was a crank sensor? 214 could be a crank, cam sensor or DIS. I would start with changing the cam sensor since it's cheap and easy to change and see what codes come up after that. With a 211 and 214 code I would say it's the DIS but the cam sensor is so cheap it's worth it to try it first.
randy'sho
95 White MTX
High Point, NC
I have read several post that have said that 211 end up being the crank sensor!
jmpSHO
Massachusetts
Continuous Memory Diagnostic Trouble Code (DTC) 211 indicates two successive erratic Profile Ignition Pickup (PIP) pulses occurred, resulting in an engine miss or stall.
Possible causes:
•Arcing secondary ignition components (coil, cap, rotor, wires, plugs, etc.).
•Loose wires/connectors.
jmpSHO
Massachusetts
randy'sho
95 White MTX
High Point, NC
no harm no foul man! I am hoping that you are right believe me! I am going to swap the DIS in the morning!
TwistedMunky
yakima,washington
replace the crank sensor. I just finished mine. I had the same problem, now I have a nice sho I just picked up for 500 just because of the sensor. I did have the rpm gauge moving when i was cranking. After I look at it maybe its because the sensor was dirty where the contacts where.
randy'sho
95 White MTX
High Point, NC
well I went to the jy today and pulled a cam sensor and a DIS off an SHO, put it on my car and cleaned my MAF....went for a drive and everything is back to normal! drove about 75 miles and she runs like a dream! thanks for all the help guys!
