fredhurderjr
Eric & I went to replace the front crank seal on Jezebel tonight & we blew something out electrical on doing the breaker-bar-on-the-crank-bolt step. Lost dash lights & all. It was freaky - I've never seen anything like it. Eric moved the starter cables & dash lights came back once, then we lost them again. No juice to the system, even with a jump pack on there. Remember that my battery is on the driver's side due to the supercharger. Before I pull the starter for testing and go through the fuses, relay pack, etc., anyone got any ideas? We kind of called it a night at that point...
Aside from the front crank seal, I think I blew at least one cam seal again as well. Oil's pretty high up on the upper timing belt cover.
We also did a compression test:
Cyl. / PSI
1 - 170
2 - 170
3 - 175
4 - 160
5 - 160
6 - 175
This is a bored 3.0L SHO Shop special, chrome rings, 5k miles on the engine, 9.0:1 CR pistons. My 91 w/ 120k runs about 190-210 per cylinder.
For those who haven't had to work with the Vortech unit crammed in there, it's a real ******
I swear it's a case of sibling rivalry between Jezzie & Monique...
White 95 SHO MTX
"Jezebel"
Teases me with occasional great runs in between break-downs.
3.2L SHO Shop Long Block
9psi Vortech S-Trim Supercharger
Eibachs, Tokicos, 96 Brakes, SFCs, STBs
PP Y-Pipe, Custom Stainless Cat-back, Bullets
http://members.home.com/fhurderjr/sho.htm
Mocha 91 SHO
"Monique"
Hi-Revs Jr. Clutch
Dynomax Cat-Back
"The Reliable Winter Car"
Cyl. / PSI
1 - 170
2 - 170
3 - 175
4 - 160
5 - 160
6 - 175
White 95 SHO MTX
"Jezebel"
Mocha 91 SHO
"Monique"
Hi-Revs Jr. Clutch
Dynomax Cat-Back
