SHOBlu
Habitual Offndr
I replaced my camshaft seals and found that there is no "o-ring" for the cam position sensor. Its just the camshaft seal itself that keeps the oil inside the engine.
I replaced the camshaft seals, front crank seal, valve cover and oil pan gaskets and that solved the oil leak. By the looks of it, all the seals and gaskets needed replacement as I had multiple leaks. Now the engine is clean and dry underneath, just how I like it.
