couple of questions
93MTXSHO_STUD
lubbock, TX
A couple of questions guys:
1) Where is the EGR value on the SHO?
2)Do you really need those expensive tools doing a 60K job?
3 Where do you get those devices that give you engine codes and how rich or lean your car is running? :confused:
qiksho
SHO Addict
Fargo, North Dakota
I believe the egr is only in california cars and auto's...could be wrongh though. Do a search ;)
2) Partly. You need valve spring compressor, and tappet holder to do the valve lash adjustment. You might need a puller. You NEED a torque wrench.
3) you can run the codes yourself with a paperclip. got to www.midwestsho.com and it will tell you how to do it and what the codes mean.
