Is it common for a car that leaks oil... to leak even more while its jacked up (and not even running)! Is this just the oil, that has already leaked, using gravity to appear to be leaking even more?
Also, the heat shield over the rear bank exhaust manifold has oil on it... where would a likely leak be originating? (I'm pretty sure my cam seals are leaking... I just wonder if it something else)
