Cooling Fans, how low can you go...not this far
1slickRED89
Guest
Toledo Ohio
Just thought I'd share my experience before this happened to someone else. in an effort to keep things cool on my 1994 ATX Taurus-car I lowered the fan controller set points to a level where both fans ran all the time once it was warmed up. my dataloged ECTs where right at 200F most of the time so I thought I was OK.
and I was, till I melted the alternator and battery.
including the cost of the new/rebuilt parts and the gel-cell I smoked, I could have gone on a nice weekend trip, including gas and a nice hotel. DOUH :bonk:
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
You might have some other issues.
Using the tweecer, I have the cooling fan in my '89 turning on right at 190 degrees.
Ive had it like that for a LONG time now.
Axianator
I am a banana!
Roanoke, TX
I have to agree with Kenny on this one. Running the cooling fans for a little bit longer than usual (for some cars) on an otherwise normal electrical system should not cause any problems. If this setup does cause problems, then you have issues elsewhere. ;)
1slickRED89
Guest
Toledo Ohio
an 89 only has one fan, 94 ATX has two.
I agree with you that a little can't hurt, I just don't think the charging system can do two 30-40 amp fans full-time. I'm open to alternative diagnosis.
whiteman_01
Well-Known Member
Hastings, MN
I have a secondary fan on my '92 that i run all the time when i am in town. Its only a 10 inch but it moves a lot of air mounted as a pusher. But even still, on the HOT days my car will climb right to 225 and stay there till i hit the hwy. I think I need a bigger Rad. But anyways i havent had a prob yet.
ribeye2065
