Cooling fan
Ishodu
Having some trouble with my cooling fan, it just dosen't come on, (most of the time) the fan turns easy. Where would I start to look?
Ishodu
The air is not working right now taking that to the shop thursday, but i thought the fan should come on when the air is turned on.
The radiator cooling fan should run continuously when the climate control is set to MAX A/C, AUTO, PNL/FLR or defrost. Only VENT and FLOOR will not cause the compressor to engage and the radiator cooling fan to run. If it is not running, it is most likely the motor's brushes that are worn out.
Markus
Ottawa, Ontario, Canada
ishodu:
If you have an ATX the cooling fans (2 of them in parallel) have 2 speeds. The first, low speed, comes on whenever the AC compressor is on and speed is below 45mph. High speed kicks in if the low speed fan is not cooling properly. I have just replaced the CCRM because the low speed fan was not getting turned on.
