MrSho
Thread Killer
So, hopefully someone can help me out. I've been having a cooling fan problem since the winter now but it never got me into trouble until now when I got stuck in stop and go, bumper to bumper traffic (unannounced parade) until the gauge was close to maxed (beyond normal markings). Pulled over and popped the hood and I could hear the coolant boiling and was overflowing onto the ground. The car is fine but I decided to try and finally figure out what is going on with the fans. (I generally only drive it to work which is 10 minutes away, all on a highway). Although I searched it seems noone has the same symptoms as me.
After inspection it seems that the fan only comes on with the AC and, I think, at high fan speed, but in 3 seconds on/ 3 seconds off intervals. I DID NOT try the KOEO test to see if it came on. The interesting thing is that when I applied 12V power directly to the fan motor it came on with the brown/yellow (high speed?) wire but not the brown/orange (low speed?)wire.
Is this normal for the low speed of an electric motor to go but the high speed work fine? Or is it possible there is a short in the wiring from the connector to the fan motor? Obviously some more testing is needed with my meter and such but I was hoping someone could point me in the correct direction
Thanks, Mike
Thanks, Mike
