Cooling fan issues
qwik huh
Harrisburg, PA 17112
I have tried search and found a lot of good info but I am still stumped. A little background. I have a 92 SHO. A couple months back during a bad snow storm the car got a lot of ice up in the fan and the fan motor burned itself up and the harness melted a bit as well. I had a 95 SHO MTX parts car so I took the fan out of that. My 92 was a 2 wire one speed, the 95 had 3 wires which I assume to be a 2 speed fan. I wired it up and it worked fine, when the fan was supposed to come on it did, just the high speed I am assuming, but the car ran fine and all was good. About a month later I did an engine swap and took the low milage motor, trans, etc. out of the 95 and installed it all in my 92 SHO. A few wiring issues but nothing major. I also replaced the CCRM with one I bought from RCM when I ordered the rest of my parts. Since the engine swap the fan has not ever worked. I swapped the old CCRM back on and still nothing. I traced the 2 brown and red wires coming off the CCRM to the fan and there is no power. I hook direct 12v to the fan and it comes on. I also have tried the Defrost and A/C and neither makes the fan come on. I checked the 60 amp fuse as well. It was good but I replaced it anyway and still nothing. Is it possible my CCRM happened to fail the same time I did the engine swap and the replacement is bad as well? Anything else I can check that I am missing? I really do not want to have to buy a 3rd CCRM if I can avoid it.
Power Surge
Palm Coast, FL
BIIILLLLLLLLLLLLLL!!!!
What's up bro? Didn't know you were an SHO owner.
Can't help you on the fan, just wanted to say hi :).
JustinSane
SHO OFF
PA SHO Shop
when you did the engine swap you said you ran into a few wiring issues could any of those be the problem? , I think the CCRM has to match the cars type and year not the motor , so the correct CCRM would be the one that was in the car, not the one the motor came from, there is a sticky thread on here about having the wrong CCRM perhaps this is your issue. sorry im not much more help as i am just starting to figure out how these SHOS tick my self.
qwik huh
Hey Sal whats going on buddy! Yes I have been an SHO owner for a long time, how the **** did you think I learned to work on cars? :) Here is a pic of my silver 92
Still cannot figure out this fan issue. I think it is time for my own relay and the **** with the CCRM running it.
Justin The CCRM is for the 92 SHO and that is the harness I used. The alternator harness and a few small things had to be changed during the swap.
qwik huh
Anyone? I drove the car today and also noticed that the coolant temp guage goes up to almost halfway as soon as I start the car. Does the 95 motor have different coolant sensors than the 92?
Power Surge
Palm Coast, FL
Bill, don't know if this helps but....
On my 90, the guy I got it from had just swapped the trans. The cooling fans never seemed to come on. I had noticed there was a resistor on the firewall that he forgot to plug back into the harness. After that, now the fans work. Might be something to check quick.
