JohnW63
I just noticed I have an intermittent leak in the driver's side of my radiator. I found a notable puddle at work, but I can't seem to get it to leak all the time. It seems wet from just below the upper hose, but the hose seems dry. There is a wrapped electical line in front of the radiator that seems wet, but I think it originates from the back side. The bigger drips come down very close to the radiator drain plug and some "T" fitting. Upon very close inspection, I think I can see two little ridges on the drivers side of the radiator that might have a crack in them. The ridges on either side of these two don't seem to have the crack, so.... After using the search button, it seems that the end caps of the radiator are prone to problems. Do my symptoms match this ? How long should I expect to need to replace the radiator ? Is the AutoZone ones an exact fit, or should I go to another source. My local 'Zone listed the upper rad hose, but it wasn't EVEN a close match. It flat out would never have fit.
Now for the confession....
The car has 130K on it. 1995 3.2L ATX SHO. While I have changed the plugs once and the plug wires, as well as the valve cover gaskets, and thermastat, I have done NO other engine bay maintenance. As far as I know , all the belts, hoses, and all the other "60K Service" stuff has never been done. I guess I'm living on borrowed time. The reason I haven't done or had this stuff done is that when I HAVE done work on the car it ALWAYS takes a lot longer than I expect. ( See my posts awhile back on an iol leak and another on rear brake problems. ) Yes, I got the 60K maintenence video on eBay, but...I never even watched it. It's also my daily driver and I need to use it, well...daily.
Feel free to chatise me or encourage me to get of my @ss. I need a kick in the right direction.
