What part of the valley you in? If you go to AZ or Checkers let me know I can help you out with my discount. Its only 10% but every little bit helps.
i'm in ahwatukee, but if i remember from what you said at the meet back in october you're in peoria? i'd probably be over in northwest phoenix/glendale area on saturday when i do it, PM me a way to get a hold of you if you'd be so kind as to extend the discount. i think... i think by saturday i'll have enough to get all the requisite upper 60k parts minus the shim packs for the valves.
my list so far consists of:
water pump and gasket
valve cover gaskets
cam position sensor
plugs
plug wires
cam seals
new accesory belts
timing belt
Radiator (new from checker or Vato-zone)
upper and lower hose
4 gallons of Coolant (for flushing out after 60k and because if i remember right this car takes just a
RCH over 2 gallons for a full system(any recommendations? i usually just run prestone II premix).
6 quarts of 10w30 ( i usually flush a quart of clean oil down into the pan to help get the old oil out of the pan, put the plug in and then pour it full)
oil filter
fuel filter
air filter
wing and a prayer.
i didnt include the crank sensor because that was done in july, i also didn't include shimming the valves because i dont have money or the time to order the shim kit. i'm going to check to make sure they're at least close to spec if not in spec and pray for the best at this point. if they're more than .015 out i think i'd be having major, noticable issues right?
i'm gonna see about the possibility of doing the front motor mount some time next month, if i wait any longer my 'polished' intake will 'are belong to tom':wave: AND then sometime between xmas and new years the old girl is getting SFCs and an H brace made over at the local 1607 millwrights training facility (woohoo SHO projects done during welding school:woo-hoo
with front and rear LCAs Tie rod ends, end links and hopefully if santa or my relatives/wife love me enough konis and eibachs.
speaking of H braces, does any one have a spec sheet or any idea on ideal distance between the front and rear of the piece that the lower control arms bolt to where the brace would go between? i mean i could make one to fit what it is now, but was wondering if there was a baseline to where it should be stock before it had 17 years of regular driving and then 7 months of abuse from me, it may be a little flexed and i figured making a brace the right demension and then pulling it with the bolts to the brace might be the ticket if it is twerked.
i got plenty of 0.125X1x1 tube, a plasma cutter and welder with an AWS certified inspector to check my dirty work after, so i figure i might as well take a swing at the H brace tas well as the SFCs. i figured i could just stitch the 1x1 together instead of 1x2, to me having the 'beam' the two sides welded together down the middle would make it stronger than a 1x2 piece.
