Coolant light comes on
waffles
Minnesota
Hello all, my low coolant light just started coming on when the resivoir has coolant and the radiator does as well, the temps seem normal. I think it may be the sensor because I took a wire brush to the probes and it temporarily fixed it, how would I go about diagnosing this issue? Thanks for any input!
the sensor can get covered w/ crud and not recognize if there is coolant there or not. sometimes you can clean it, and sometimes it must be replaced.
waffles
Minnesota
Thanks, what is the sensor called? I can't seem to find it on the web.
shotime1994
AirHammerAndrew
New York
Don't think you by the sensor aftermarket. I have several extra bottles for mtx cars. Try your local j/y
waffles
Minnesota
Update, I bought the last one in the country from the ford dealership:naughty:
jimtash
nc
Same issue and same fix. Luckily I had a spare sensor though.
