Coolant Level Sensor Location
MOSHO92
Modesto, CA / San Jose, CA
Where is this located?
My HUGE low coolant light has been going on randomly and I think the level sensor may be at fault. The radiator is full and so is the resevoir.
What do you think?
olympic
Saskatchewan, Canada
I'm pretty sure it's in the coolant bottle. Sometimes the sensor just needs to be cleaned. Other times it needs to be replaced.
Dr.Evil
No Dif Pin!
Sparks, Nevada
its at the bottom of the overflow bottle. if cleaning it doesn't work, just disconnect it and keep just check the level when you change your oil.
Rockledge
Pluggin' away
Connecticut
Take off the cap and pull it out of the coolant bottle and you will see the sensor attached to it. Clean the two metal prongs and see if that helps.
