coolant leaking?
ThatShoGuy
michigan
so i been battling a coolant leak fix one something else go's and so on.
fixed the hose that is under the water pump and runs to the heater core, i think. well i fixed the u and about 4 inches after.
and i also thought the little line that runs from both heads to the coolant tank might have a leak?
haven't got down to it yet to fix since i got the remove the whole upper intake parts.
but have the next 2 days off to do so.
today i was on my way home stopped and put gas in it. came back out and the car had a good size puddle foot by foot and couple other spots. sub frame was soaked when i looked underneath. i noticed the started was wet the rear(trans ended) of the motor running down the trans and the front gets wet along with the belts and they have started to slip a little here and there. today was the most i seen it leak! so i hope to find the leak
also steams once the motor is up to temp ...
thanks
***on used head bolts and gaskets, NO OIL IN THIS COOLANT ALONG WITH NO COOLANT EVER SEEN IN THE OIL!***
The Y fitting for the small hoses that go to the tank is delicate and may break. I have some brass ones if you need one.
ThatShoGuy
michigan
yea i think i might have hurt it one time removing the alt dropping the sub frame. thanks for the offer ill let you know!;)
ThatShoGuy
michigan
well i found at least one more leak!
the Y was brittle so that broke while workin on it. along with i found the real leak this hose is slit! and the clamp was so lose i pulled the hose off.....
attachment.php
attachment.php
plan to be able to snip the bad end off and reuse the hose and just run to the auto parts store today so i can just get it done....
thanks for any help guys!
guess my cell phone does some good pic's (its the lg shine.)
ThatShoGuy
michigan
this is pretty much fixed unless something else springs a leak...
i dont think the radiator is far behind!:nut:
