Coolant leak
dkal
Northwest
I recently had my 95 SHO serviced at a Ford dealer. I had the timing belt replaced, and the engine diagnosed since the check engine light came on intermittantly. The engine diagnosis found a code indicating my temperature sensor was not operating properly, so I had it replaced. Since then my engine has been leaking coolant from the part of the engine where the timing belt was replaced. My question is if I had my timing belt replaced, is it possible that a coolant leak could result from the service performed by the dealer? :confused:
Bizzy
Wrong forum...moved to troubleshooting section.
ISHOU
Centennial, CO
How many miles on your 95? Check for simple things first. The coolant resevoir and the lower radiator hose are in that area and could be leaking. High miles could mean the water pump is starting to leak and needs replacing although a "good" tech should have noted the leak and let you know. Is this a reputable dealer???
<small>[ July 11, 2002, 11:43 PM: Message edited by: ISHOU ]</small>
