I've got a little problem. I am peeing coolant... out of the little tube that runs from somewhere in between the heads into the back side (closest to the firewall) of the throttle body. The tube has a little hole in it, so I pulled it off and tried to replace it with another section of tubing. I guess the tubing is a little smaller in diameter. That, and the fact that the tube is shaped to make the curve into the TB, lead me to believe that the original piece is a pretty specific part. (like the upper coolant hose is specifically shaped) A cross section of te tube shows little holes running alonside the main passage, if that made sense.
I haven't looked for one yet, but is there a specific name for this little hose? Anyone have one without holes?
