kd7kmp
Several weeks ago I flushed the cooling system on my 1995 MTX. After doing this I started to loose coolant slowwwwly. I chased the leak down to where the drain valve screws into the radiator. For my own sense of security I removed the radiator to verify that the tanks weren't cracked and the core was okay. They checked out fine. It definately was coming from the drain valve. Thinking the rubber o-ring was bad I replaced the valve. I even put blue RTV on the treads of the new valve. The leak slowed even more, but the problem still exists. I don't want to purchase a new radiator if I can help it. Is this a common problem with SHO radiators? Thanks for any help.
Kevin
Kevin
