Marccus
OK, I'll try my best to explain this. I replaced the thermostat and the gaskets, and short rubber connector piece that connects the two halves of the engine cooling system.
There is a central pipe that runs underneath the fuel rails that has an O-ring on it and I replaced that also. When I bolted in the flanged pieces that are connected by the short rubber piece (which is held on by a spring type clamp) I get an intermittant leak of coolant.
I'll be at a red light and I'll see a little smoke come out of the hood with a coolant smell. When I pop the hood, I can see a little coolant on the bell housing but I can't see exactly where it is leaking from. It's not leaking from the coolant lines on the throttle body.
It's difficult to see way in there even with a flashlight. I also get a puff of smoke from coolant at the camshaft seal end right under the fuel rails. That would be where that central pipe runs and ends with another O-ring.
The spring clamp holding on the rubber connector seems like it would be better rplaced by two worm gear clamps (like ABA).
Any ideas? shrug
Any ideas? shrug
