SHOup&SHOout
SHO Rookie
My mechanic told me recently that the SHO has a unique cooling system that NEEDS, i repeat, NEEDS to be Bled properly after you change a T/S, Hose, Radiator, etc....Is this true....?This is coming from the same mechanic that took 4 hours to figure out my CrankPositionSensor was gone at around 60-70k..?
Reason im asking is because i recently developed a leak in my cooling system...Found out it was a combination of 2 things....Hose had ruptured...and my overflow bottle split along the seams on the bottom....I fixed the bottle with Marine Grade 5200 Sealant and replaced the hose....But now everyonce and a while i need to add coolant and i smell coolant burning off....at first i thought it was just the coolant that had sparyed the motor when the line ruptured and i needed to refil it because the air bubles were bleeding themself into the overflow bottle??...but now im worried that by not bleeding it when i replaced the hose i did something to the system...
Any thoughts are appreciated...
Thanks....
Thanks....
