The sensor is on every Ford car in the early to mid 90's with the electronic climate control. It is discontinued - and will be impossible to find anywhere. One of the guys on here picked up the last 4 I think that exsisted. That hard metal line is also discontinued and you won't be able to get from Ford either. However, if you go to the WTB portion of the forum here - you could talk to one of the SHO salvage dealers here on the forum and I'm sure that they could get you one in good shape (the pipe and the sensor) - your talk to one of the guys parting out their SHO's and they can probably hook you up with one in good shape also.
Since you will be replacing that one also...I would inspect the other hard line pipe that goes to the heater core...maybe you should replace both.
I would reccommend cleaning (removing all rust) priming, painting, sealing and all that good stuff to the new pipes....
Doug
