Coolant explosion
Devin
3.Slow
Pacific Northwest
I was accelerating from a turn onto a highway, I hit about 5000 in 1st, and probably the same in second and I heard a pop and steam started billowing from under the car, through my vents and around the side of the hood. I parked and checked and the passenger side heater hose blew off of the metal section. It was violent enough that I heard a "popping" sound.
I don't know if this is subpar clamping force, or could the thermostat or radiator cap cause this?
Lightning
Alberta
has the hose been replaced in the last decade and a half?
If not, then my guess would be that the hose was old and got tired of waiting to be replaced... ;)
SHOKING91
******* OUt
OKLAHOMAAAAAAAAAAAAAAA
thats happened to me.
when i first got my sho running after the clutch job i blew a heater hose.
you might want to check your hoses to see how old they are
AREA 91
PA SHO SHOP
Area 91
If the hoses are origional, replace as many as you can, while your in there.
Wow! That was a run-on sentence and a 1/2.:oogle:
shovermont
unleasing my 91
Vermont
i bet old hoses. and as snoop dogg says. drop it like its hot.
but evan says
pop it likes its hot.
damn hos.
wait i mean hose. haha
Devin
3.Slow
Pacific Northwest
lol, if only I was drinking milk while reading that! :woohoo:
The hoses are new. The metal lines are not, of course. The thermo is new as well. I re-clamped all of them and refilled and I didn't notice anything awry when pushing it a little ******* the way home. It took 1.5 gallons to get it back full again.
hawkeye18
Sorta cares
Norfolk, VA
if you don't remember when the last time you changed your radiator cap was, change it. It's probably the easiest maintenance you could ever do on a car. They're like $6. Even if you can remember, change it. They fail frequently.
itwonder
VA
If it blew off of the end where the hose is crimped onto the metal pipe, cut off the old crimp material and replace with a worm type hose clamp. If it blew off of the heater core end, then it was probably an old clamp and bad hose. Replace. While you are at it, replace the radiator cap with a new Motorcraft one. You might want to borrow a pressure tester from Autozone or Advance to make sure the whole system is tight.
