Huntervf
Bored now
Since getting the 89 back from the trans shop I've had some real trouble shifting...it's very notchy and at times I just plan can't get it into gear. Everything in the trans is new/replaced save for gears 1&2, 4&5, the output shaft and the clutch (OEM, with approx. 7k). I'm running Royal Purple ATF.
I've been doing a little checking around about different fluids and friction modifiers. I would really like some thoughts/opinions on different fluids & modifiers...this isn't my strong suit and I'm desperately wanting my trans back to shifting decently. When I had trans work done back in April I was using the IPT stage IV clutch and regular trans fluid, and after a short break in period (that's when I had new synchros/rings etc. installed) the trans shifted good.
As always, any and all advice is appreciated!
