broach ronald
i have a 94 mtx blowin my eec fuse. ford said it was in my constant control relay module. replaced, and one year later fuses are blowin agian.it seems problamatic to first and second gear and turning right,so theres a short some where. i found some wires that are frayed and exposed and grounding out. If you follow the ccrm wire harness down to the drivers side it is joined by 2 connectors. My interest is in the one connector that has 4 wires and is a lt. brown oval shape and rest next to this 3 in. round canister. The wires join the ccrm wire harness and runs back to the top of the engine and im lost here .What i am trying to find out is where this connector goes and how should i replace it. also, is there an alternative to the 150.00 for the ccrm?
