roswell998
I've received some different opinions on flipping shims. A search of the forum also shows a little difference of opinion over time but probably the latest info available is accurate.
1. Is it absolutely OK to flip shims over?
2. If used surface looks OK, would you still recommend flipping anyway just to get the best and newest surface exposed? (FYI, car has all original shims and 106K miles.....none out of tolerance at first 60K)
3. If flipped, will numbers written by hand on new bottom side with a Sharpie permanent marker hold up for later reference?
Thanks
Ashton
Thanks
Ashton
