gregr
I am puzzled. Last night after work, I jumped in my car to notice that the Climate Control, turn signals, and rear defroster were dead. I pulled fuse #5 (15 Amp) and it was blown.
manual say this fuse controls:
-Backup Lamps
-Climate Control
-Hazard Flashers
-light for keyless entry
-rear defroster
I did not check the Backup lamps, but I know the hazards worked just fine. The turn signals were dead. It also seems like the light for keyless entry was OK too.
Anyone have any insight? So far I blew 4 fuses within about 60 miles of driving. The systems work OK for a while, and then suddenly blow. The only connection I can see is that they blew when I hit the brakes. Not everytime I hit the brakes, but ocassionally.
I am really stumped. Help! It's cold out and I am running out of 15 Amp fuses!
Greg Raciti
SHO Forum Webmaster
93 Emerald Green MTX
Performance Plus high flow stainless Y-pipe
Scott 2.5" Stainless
Exhaust with Edelbrock mufflers
SHOShop Cold Air Induction
SHOShop Underdrive Pullies (to be installed)
Romar Enterprises Subframe Connectors
SHO NUT Performance Aluminum Subframe Bushings
24mm front sway bar
26mm rear sway bar
Energy Suspension poly bushings
SHOShop LPM
SHOShop UDP's (coming soon!)
IPT triple gauge pod with Autometer - Volts, Oil Pressure, and Water Temperature Gauges
-Backup Lamps
-Climate Control
-Hazard Flashers
-rear defroster
Greg Raciti
SHO Forum Webmaster
24mm front sway bar
26mm rear sway bar
SHOShop LPM
