Computer swap?
SHOW OFF
San Antonio Texas
Two questions. Where is the main computer located at on my 94'. I think I know but just want to make sure and can I swap it out with another 94' with no problems? Thanks.
kevinspann
Don't take my advice.
Richmond VA
Firewall, passenger side.
Open the glovebox, and then push the sides of it in to let the door down all the way. The ECU is up in there, you should see it at the top of the firewall, with a bracket holding it in.
As long as the replacement ECU is the same code, then yes, you can swap it out.
