vortex2450
Buying Parts...
The story is that after I ran some seafoam through the my mtx today I pulled all the plugs to clean them and check all the gaps, I figured I would test compression while I was at it. Wrong...
I simply fed the hose into the plug well and hand tightened it just enough to hold a seal. But when I went to unscrew it the hose spins inside the fitting (no adapter, the fitting on the hose was the correct size). I've tried pushing/pulling while turning on it for about 15 minutes with no luck...
It's stuck in cylinder #6, I've search through 4 pages on google and came up with results like cutting the hose and using a long flat head to turn it out, using loc-tite or superglue. I spent $50 I really didn't have on this tester and don't want to hack it up, but on the other hand I need it out of my plug well..
I realize that I definitely should have applied some anti-seize on the fitting before hand but that doesn't help me now.
This seems to be a common issue people run into, and you guy know have deep the #6 plug well is so isn't easy to get too by any means. I'm going to pull the intake tomorrow morning to give me some space.
Any input? This is such an annoyance, I go out to clean the engine clean today and I come back in with a friggin hose sticking out of the rear cylinder bank....
help?
help?
