Coilovers
SinisterSHO
Rust free
630, IL
Okay. call me a newbie or whatever, but I'm kind of confused of what exactly a coilover is. As far as I can tell, its a coil spring over a strut? Do coilovers offer more adujustability? Are they expensive?
I see Tim has the IPT coilovers, and I think when I try to go to the IPT site, something doesn't work right, maybe theres a broken link.
olympic
Saskatchewan, Canada
Advantages of coil-overs:
-ride height is easily adjustable over a wide range.
-they use standard 2.5" ID springs which are available in any length and rate you want at a reasonable price.
-they're lighter and more compact.
IPT doesn't sell them anynmore but they were $900 which didn't include struts. Just the springs, collars, perches, etc.
LI_SHO
Long Island, NY
There are still sets of coilovers circulating?? Anyone who has a set for sale let me know...I may have a buyer for you immediately
SinisterSHO
Rust free
630, IL
Kinda answered my question, But what exactly makes a coilover, a coilover? Why is the stock system I have on my car, not a coilover system?
Shoaz
Studly dood
Scottsdale, AZ
Opal Frost ATX:
Usually when people use the term "coilover" for performance suspension they're implying a threaded sleeve, adjustable perch, and springs selected from the standardized diameter spring sets that are available. Typical spring sizes are selected from the large number springs available with 2.5" inside diameter and varying lenghts. Springs are often available in 50 lb/in increments, e.g., 450, 500, 550, etc., and uncompressed lengths anywhere from 6 to 12" etc., etc.
Although the stock struts have the spring coil around the strut, it doesn't have the adjustability or common spring form factor that most people have in mind when they say "coilover".
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
You can also get coilovers from Ground Control. They are a little bit cheaper and I talked to some one with them and they liked them.
1fastsho
Athens Ga
coilover comes from rwd applications. say like a mustang, the spring and shock are seperate. "coilovers" are a conversion to place the spring onto the shock. a mcpherson strut is a non adjustable coilover design but not a true race tyoe coilover system.
SHOfun 93
Euless, Tx (Fort Worth)
Make sure you replace the strut rod bushings when you do...I didn't on my 93, and I get a popping when I go over bumps. Kinda irritating.
But as far as handling..there is NO SUBSITUTE! hail
haydenm315
Reisterstown, MD.
Opal Frost ATX:
If you're still confused about coilovers, check out the suspension on a hobby quality radio control car. The spring and strut are combined into a single unit. All of the benefits were already mentioned so I won't repeat and just give this example. Another advantage to coilovers is the ability to use a rally spring setup. THis is accomplished by using 2 different kinds of springs mounted on the coilover. On top is a softer spring that maintains a smooth and comfortable ride. Under that is a much stiffer spring. When you push your car, the soft spring is compressed and the suspension becomes more stiff depending on how hard you run the car. A friend of mine has these on his vw corrado and it's sweet.
