Coil Spring Seating problem
Sylentnite
Mr. Nite
NC
I'm installing new Moog coil springs & sensa trac struts on my 93 atx. I noticed that the Moog coil was a lot taller and had an extra coil, versus the stock spring. I decided to cut 1 coil off the Moog springs from the top, but I can't get the strut mount to now seat properly on the coil. Since cutting the coil, it no longer has a flat surface for the strut mount to sit firmly in. I'v searched and seen this an option for this spring, but not quite sure what i'v done wrong.
kevinspann
Don't take my advice.
Richmond VA
Should be fine with weight on it. Just make sure it's in the right position on the bottom.
