Ok, so I have a check engine light for about 5min in the morning, about the time I hit the highway entrance they go away. On top of that my secondaries don't do much. When I hit 3800 RPM they open, and the car bogs down.
Am I able to pull the codes doing a KOEO even after the check engine light has gone off?
I thought maybe it was because the car was still cold, but I recall the secondaries opening up plenty of times while the temp gauge was still out of the normal temp range.
That brings me to something else that might have something to do with the problem. I can drive 20min to work and my car still won't be at a normal temp, I have never seen it make it off the blue line on my drive to work. The weather here is a little cold, it was 41 when I left this morning.
Is it possible my thermostat is stuck open?
I don't have any other means of pulling the codes.
--edit--
Just went out for lunch, its 60 outside right now, no check engine light this time, and still no secondaries.
--edit--
