Codes CLIMATE: 115 & 125 HELP
115 U1073 Engine Coolant Temperature Signal Refer to the Powertrain Control/Emissions Diagnosis Manual.
125 U1341 Vehicle Speed Signal Refer to the Powertrain Control/Emissions Diagnosis Manual.
I would take out the football and make sure the connectors are clean and attached securely. After that pull the PCM connector off and make sure it is clean and not corroded.
