Lorenr
The 89 SHO just died at a stop sign and took awhile to restart. Power seems a little week but the car seems to run fine now.
I decided I needed a scanner and purchased a fairly good one.
The KOEO gave a code 11, but the KOER gave a 49 and also a 95. The code 49 said the test defaulted timing to 10 degrees BTDC which could account for little loss of power. I'm assuming that only the computer advances timing.
The vehicle ID calls for a Y code for the scanner, but the scanner acts like it wants to test an automatic transmission.
Where am I at on this? The crankshaft position sensor was replaced about 25 K ago, and so was the camshaft sensor, but seems like a similar problem.
