codes 26, 83, and 87.... anything to do with the crank sensor??
TL8apxrx7
Missoula, MT
now my troubles are getting worse... motor still won't start and now its giving me three different codes...
26: mass air flow sensor or vane air flow sensor or transmission trmperature sensor fault
83: EGR solenoid circuit fault
87: fuel pump primary circuit fault
what is going on with my car?????
LJRuddy
Pop lock n drop
Poaceae fields
Hmmm.... what are you doing with a Gen 1 that has an EGR? is it a cali car?
if it isnt, you have some issues.
The first, i would guess because you have not been able to start the engine... that means it isnt warm so it cant read codes correctly? Or maybe you have a bad MAF... You have any other spares layin around?
The last could of been from a time you stalled the engine when starting from a stop. I dont think any of this would cause a no start issue... lead alone a crank sensor problem
Rockledge
Pluggin' away
Connecticut
Check for fuel pressure at the rails.
Do you hear the fuel pump prime when you first switch the key to the "on" position?
TL8apxrx7
Missoula, MT
I have fuel pressure and the pump does its thing when the key is switched on, I'm not getting any spark
projectSHO89
SHOless In St L
Rockledge said:
Or a faulty DIS module, or maybe a bad ground somewhere.
There's a whole bunch of things that can cause a "no spark" condition. All of these, including the CPS, are on the list of possibles.
The diagnostic that Rockledge pointed to has the answers. If you don't have the techical knowledge or equipment to follow the diagnostic, you'll need to either find someone who can do it for you or you'll need to do the needed learning yourself.
Of course, you just start hanging parts on the engine and see if you get lucky.
Steve
